CamaroZ28.Com Message Board
-   Drivetrain (https://www.camaroz28.com/forums/drivetrain-44/)
-   -   not shifting (https://www.camaroz28.com/forums/drivetrain-44/not-shifting-879288/)
kenx82 May 13, 2014 08:42 PM
not shifting
speedometer not working transmission not shifting out 97 Z28:think:
Injuneer May 14, 2014 08:02 AM
Re: not shifting
You may get a better response on "Drivetrain" rather than "Car Audio and Electronics". I'll move the thread there for you.
Have you scanned it for codes? Sounds like a vehicle speed sensor (VSS) fault. Check the VSS (tailshaft of the transmission) and make sure the harness is plugged in to the sensor.
12SCNDZ May 14, 2014 08:38 AM
Re: not shifting
Like Fred said. The computer needs to see VSS before it will command the trans to shift. It's most likely either the VSS itself or the wiring.connector.
Frank
