No line pressure in tranny. Bad pump?
According to my tci box im not getting any line pressure when the car is running No gear works. Tranny is full. Is there anything i can test or is the pump just mechanical and it failed? Drop the pan anything
Dont know if this matters or helps cause pump failer. What i was doing before problem:
Lanched the car on the brake. Made a pass through 2nd then lifted. Car pulled normal through second then i put it back into overdrive to cruise and the problem was there
thanks
thanks
thanks for the reply. Yeah i just pulled the cooler line and no fluid at idle. Are the pumps on the 4l80 something that i can get to by pulling the front cover off or does the trans have to come apart
thanks
thanks
Deadbolt24
Jan 19, 2015 01:29 PM
Jul 4, 2005 05:00 PM
