Need your help with clunking noise
Old Jul 9, 2005 | 09:34 AM
Derek_91's Avatar
I have a 2002 Z28 that i've had for about 3 months. It has this clucking noise that sounds like its coming from underneath the passenger floor board. You can also feel it in your feet if your over there. It only happens when the cars accelerating. I thought mabey it was a suspension peice but i got under there and looked and everything seems to be ok. I am very confused so any help would be great.
Derek
Old Jul 9, 2005 | 10:16 AM
Mikael's Avatar
Re: Need your help with clunking noise
Transmission mount is broken.
Old Jul 9, 2005 | 01:37 PM
Derek_91's Avatar
Is that a common problem with an M6?
Old Jul 9, 2005 | 01:43 PM
Mikael's Avatar
Have you recently had bad wheel hop? If the drivetrain takes a hard hit, then it is common for it to break (its actually just rubber, so i tears). They dont' really just "go bad" though. Not too expensive and not too hard to replace.
Old Jul 9, 2005 | 11:55 PM
Strahley's Avatar
It's very possible the tranny mount broke on you. You can buy a polyurethane one for like 20 bucks or something through Thunder Racing. Try replacing the mount if you want to, see if that solves the problem
Old Jul 9, 2005 | 11:59 PM
BirchMan98z's Avatar
I've broken dozens of tranny mounts. Easy fix, cheap, and offers good peace of mind. They don't break unless you're really ripping on it i.e. dumping the clutch while already rolling at 30mph.
Old Jul 10, 2005 | 09:22 PM
Derek_91's Avatar
Ya ill get one this week and try it. Thanks for the help.
Derek
Old Jul 11, 2005 | 09:27 AM
angel71rs's Avatar
Someone just told me Autozone is now stocking poly tranny mounts. Might be a better option for someone that needs it asap.
Old Jul 13, 2005 | 04:18 PM
Derek_91's Avatar
I've been looking for a mount and the only one i can find is from the dealer for $65. Every where says they cant get one in because its so new and that the changed it for the LS1. Is this true? And does anyone know any company that would sell a polyurathane one and its part #? Thanks for any help.
Derek
Old Jul 13, 2005 | 08:59 PM
fade2blk500's Avatar
Go to autozone and look around, you'll find the energy suspension tranny mount for about 20 bucks.
Old Jul 14, 2005 | 09:57 PM
krow's Avatar
to find out if it is the tranny mount, just stick a crowbar between the tranny and the mount and push down on the crowbar a little. if u see cracks or separation then thats what it probily is. If it's not that check the shock and strut towers, ball joints, and stablilzier links. hope this helps
Feel free to look up my problum about a bad tranny situation, I really need help
autoxr166
Sep 25, 2015 04:21 PM
rideordie
Sep 7, 2015 08:22 AM
colts0455
13
Aug 7, 2015 09:15 PM
GT what?
Jul 14, 2015 10:17 PM
colts0455
Jul 7, 2015 07:19 PM
