Need help FAST!
Old Dec 24, 2003 | 05:01 PM
neversummer's Avatar
Need help FAST!
I got an axleshaft - used - and am afraid of putting it in. Check out the pics. The teeth are rubbed down on the used one, whereas my axle shaft w/ 191,000 miles still has new looking teeth. Will I run into any problems with the used shaft? Other than I hope it isn't bent like my last one.
Thanks. Nate.
http://f2.pg.photos.yahoo.com/ph/nev...r=/axle+shafts
I guess what I'm asking is should I just fork the money for a new one, or through this in and call it good? Thanks a ton.
Old Dec 24, 2003 | 07:31 PM
funina91ss's Avatar
you will be fine with that one. I couldn't tell from the pics but I am guessing the rest of the slines are fine? It should slide right in if not you might have to file the edges for it to go in easy.. IMO see if it slides in first without any problems.
Sean
Old Dec 25, 2003 | 02:19 AM
Yeah, I was in a rush to finish car and finish Christmas shopping, chores, etc. Anyway had my Dad look over axle and I went with it. Seems to run fine, not bent which is good. And splines are holding fine, went in well. Never done this before so I freaked out. Shimmy is gone. It wasn't even that bad before, but WOW - I swear it feels like a Cadillac Now! Got to get to 90 mph cuz that's where it felt like the car was about to fall apart.
Novo
Jun 14, 2016 02:58 AM
Jeff1904
Jun 5, 2016 05:00 PM
football4life
Oct 4, 2015 07:48 AM
Matt Dreessen
Sep 9, 2015 09:58 PM
damnyankee36
Sep 9, 2015 07:06 PM
