need help with an axle problem.
Old Mar 14, 2005 | 11:18 PM
RedWS6TA's Avatar
my buddy has a 98 ta that has tcs and has a bent axle and i have a axle out of a 97 with non tcs. and i was wondering if it is possible to remove the ring from the tcs axle and put it on the non tcs axle. if anybody knows if it can be done or has done it please let me know. also wanted to know if i would have to have a bearing press to do this. thanks in advance for the help
Old Mar 14, 2005 | 11:24 PM
1BAD86Z's Avatar
Re: need help with an axle problem.
Everything will work on the other axle, you just need to reuse his old backing plates and brakes with the sensors.
Old Mar 14, 2005 | 11:33 PM
RedWS6TA's Avatar
yes we will use his rotors and stuff but all i will need to take off of his axle would be the tcs ring right?
Old Mar 14, 2005 | 11:57 PM
Klypto's Avatar
yea, only way to get the ring off is to pull the axle, and heat it up to let it slide off.... (im pretty sure your talking about the little teeth things near the rotors... i did this when i snapped my axle....
cory
Old Mar 15, 2005 | 12:03 AM
1BAD86Z's Avatar
On the good housing the axles do not have the pilot for the rings, you will have to reuse his axles also, sorry i missed that.
Old Mar 15, 2005 | 09:45 PM
RedWS6TA's Avatar
dont really understand what that means?
Old Mar 15, 2005 | 09:58 PM
1BAD86Z's Avatar
The axles from the good 3 chanel do not have a pilot on the axleshaft to accept the other axles abs ring.
2QUIK6
Sep 17, 2016 02:31 PM
RUENUF
Mar 13, 2016 03:37 PM
IndyZman
Oct 22, 2015 02:17 PM
force10
Jul 30, 2015 04:56 PM
realistyc
Jul 28, 2015 07:32 PM
