NEED HELP ASAP! Transmission install
Old Jun 5, 2004 | 01:06 PM
coogsLS1's Avatar
changing the clutch out. got everything out and the clutch/bell housing reinstalled. But now, we cannot get the tranny input shaft through the clutch and flywheel if our lives depended on it. any tricks, it seems like we have tried everytyhing. thanks for any help, we need it!
Old Jun 5, 2004 | 01:29 PM
coogsLS1's Avatar
anyone?? BTW, does the pilot bearing need to be removed/replaced?
Old Jun 5, 2004 | 01:34 PM
88irocz28's Avatar
Sounds like you have a misaligned clutch disc. To get the input shaft through the clutch disc, try rotating the shaft a little bit until the splines match up and it slides through. To get the input shaft seated in the pilot bearing, try this
Make sure you have adequately greased the pilot bearing and that none of the needle rollers in there have fallen out.
EDIT: CRAP!!! I just noticed you have an LS1 car. If that's the one you are working on, then that trick won't work. It works only with the LT1's pull style clutch.
Old Jun 5, 2004 | 01:40 PM
Loony's Avatar
you could try heating the clutch/flywheel to make it expand...possibly. But yea, make sure you got the splines lined up.
Old Jun 5, 2004 | 01:43 PM
88irocz28's Avatar
IMHO, that's the perfect recipe for warping your flywheel and losing the temper of the springs in the pressure plate .
Old Jun 5, 2004 | 01:49 PM
coogsLS1's Avatar
I have no clue, I think I am going to have to back the tranny off again and take a look at the pilot bearing...
Old Jun 5, 2004 | 04:36 PM
carlos64030's Avatar
Insert the drive shaft into the tranny and use it to rotate the input shaft to help align it with the splines in the clutch. If that doesn't work...try to realign the clutch.
Old Jun 5, 2004 | 04:44 PM
Do you have an actual bearing or a bushing? Either way...I would replace it while you have the tranny out. FWIW...from my understanding, the bushing is suppose to be more reliable.
Old Jun 5, 2004 | 07:58 PM
88irocz28's Avatar
Carlos, that is one bad *** car you got man . Very nice!!
BTW, how did you lower it so much. In some of the pics it looks like the body is resting on the garage floor .
F'n1996Z28SS
Aug 23, 2023 11:19 PM
jackpawt883
Feb 26, 2015 09:04 PM
Collector Car
Jan 5, 2015 10:58 AM
ro2207
Dec 4, 2014 06:18 PM
thenewkid
Nov 27, 2014 09:41 AM
