missing 3rd and fourth
Old May 6, 2006 | 02:10 AM
red1997blazer's Avatar
I have a 4l60e with bolt-on lt1 and pcm4less pcm out of a 94 camaro and I have a problem.
Stock transmission never had 4th when I put it in the truck and 3rd went out shortly after.
So I had a gm transmission mechanic rebuild it with parts from http://www.transmissioncenter.net/4L60E.htm I got #k2 which came with their wake up kit and bought a new 2600 STALL Torque Converter.
I filled up the TC and installed the transmission and everything was working perfect. I even checked to see when the stall was kicking in and if the torque converter lockup was working right with TTS scan program.
I put about 7,000 miles on it and all of a sudden it would lose 4th and then third. If I came to a complete stop they would work for a little while then go out again. So when I got home I checked the fluid with the truck running and in park and the level was right and the fluid looked fine but smelled a little.
My tranny guy said he'd take it apart and look at it for free, all I have to do is take it out for him.
I don't want this happening again. So I called transgo to ask about there shift correction kit and they said since I had a 94 I had no pwm and that kit would not fix my problem of losing 3rd and 4th.
Should I tell my builder to leave out the load realease springs on 3rd and 4th?
Someone please lead me in the right direction. I thought about the solenoids going out but if one or both went out there's just no combination to lose 3rd and 4th.
Old May 6, 2006 | 04:43 AM
30thTA0525's Avatar
Re: missing 3rd and fourth
check your wiring especially the harness where it drops down behind the motor is is a shifting problem like it wont shift? i had a problem like that but it was with shifting from 2nd and downshifting anytime and after i changed out a good trans i figured it out after seeing the wires i cant beleve it shifted any gears
Old May 7, 2006 | 05:58 PM
Wires are all fine, I dropped the tranny and took off the wiring loom and everything looks fine. Any other suggestions?
Old May 8, 2006 | 06:38 AM
30thTA0525's Avatar
might replace the syilanoids and spare pull out the pressure switch plate and clean up all you can with some brake cleaner other than that i duno man
KYWes
Jun 14, 2022 06:52 AM
asilomar244
Jul 12, 2015 05:53 AM
Jmj93z28
Jul 8, 2015 10:01 PM
Jmj93z28
Jul 8, 2015 06:58 AM
simple
Aug 2, 2002 03:30 PM
