In middle of T56swap small question.
Old Apr 20, 2011 | 02:34 PM
SilverZConvertible's Avatar
I'm nearing the completion of the swap. I installed the shifter today and tested it with the ignition off. Its actually pretty easy to go into reverse. I thought that reverse lockout solonoid was supposed to prevent it from going to reverse with the ignition off.
Is the gate open when the car is off? Or is it really that easy to hit reverse?
Old Apr 20, 2011 | 04:26 PM
Chevyssoccer's Avatar
Re: In middle of T56swap small question.
I thought it was only at speeds higher than 3 miles per hour, or something like that.
Old Apr 20, 2011 | 05:05 PM
Yeah thats correct.
Guess I'm wondering is the gate supposed to be closed when the car is off?
Old Apr 22, 2011 | 03:10 PM
96TurboTA's Avatar
It will shift into reverse when the car is off.
Old May 3, 2011 | 10:24 PM
Actually the gate is closed when the car is off and open when you put the key in. The gate will close again once you exceed 3mph. You can actually hear the solonoid if you put your ear down to the shifter when you turn the key. I got that part all sorted out. Just reporting back for future viewers.
WobblySausage
Oct 7, 2015 02:44 PM
WobblySausage
Oct 7, 2015 10:09 AM
SEOJustin
Sep 24, 2015 04:39 PM
mmf_1013
Sep 12, 2015 08:56 PM
