McLeod Street Twin
I don't find it hard to install the master anymore, after installing it for the 4th time.
I found my master cylinder leaking and there was an issue with the end fitting. There wasn't sufficient clearance machined into the notch to clear the cylinder. The fitting was actually on a very slight angle allowing brake fluid to seep past the seals. I had to file away material to allow the fitting to seat properly.
Seals fine now!!
Seals fine now!!
