M6 Difficult Shifts
Old Oct 15, 2004 | 10:32 PM
ut's Avatar
ut
Help - M6 Difficult Shifts
93 Z28 with an M6 and today it started to become very difficult to shift into any gear, especially 1st and reverse. I had to jam it pretty hard to get it into gear and drive it home. When I got there I checked the slave cylinder reservoir and it was completely empty. I'm assuming this would indicate a leak somewhere??? I filled it back up with fluid - don't see any drips - but shifts are still very difficult. Any ideas? Thanks.
Old Oct 16, 2004 | 08:06 AM
Roadart's Avatar
Re: M6 Difficult Shifts
Have you checked the tranny fluid level? Also did you bleed the clutch system? You may still have air in the lines. I am using a 93 tranny and I had similar problems...
Good luck.
If both of those arn't the case you may want to replace the Master/Slave assm. Pretty easy R/R
Old Oct 20, 2004 | 11:45 AM
ut's Avatar
ut
After letting the car sit for several days it is shifting OK now. Strange...only thing I did was fill up the fluid reservoir with DOT3 and let it sit.
n2oblkz
Oct 22, 2015 02:31 PM
WobblySausage
Oct 7, 2015 10:09 AM
Bxlt1
Sep 29, 2015 03:18 PM
marlar98
Sep 19, 2015 07:53 AM
