m6 conversion
m6 conversion
Just curious how much work is involved with an A4 to M6 conversion. I found a wrecked camaro with the interior color I want in my car, motor, trans, wiring harness, etc..... I just don't want to pull the wiring harness off my car, and am curious is it just as simple as plugging in the M6 ecm and all mechanical aspects?
Re: m6 conversion
Other than cutting the holes for the clutch master cylinder and shifter, it's just swapping parts. You can use your auto wiring harness, you just need to do some minor rewiring. You will need an M6 program flashed into your PCM. If your car has 2.73 gears you will need to change the gears, unless you use the 93 T56 that came with the 2.73 ratio. You can just swap gears or get a complete rear.
RUENUF
Mar 13, 2016 03:37 PM
Henson071
Dec 30, 2015 09:55 PM
tdigger9899
Sep 7, 2015 10:56 AM
