lt4 clutch disc in z28
Old Sep 23, 2003 | 12:39 PM
zjet's Avatar
i was told the lt4 disc wont work with a camaro flywheel is this true .thanks
Old Sep 23, 2003 | 01:01 PM
PatriotTA's Avatar
It should work if its the LT4 Camaro disc. Although I think some of the LT4 discs may have been built for the dual mass flywheel, which was used in the Corvette. That means that the disc is not dampened, its a rigid disc, because the dual mass flywheel is dampenend instead. A rigid disc would not be very streetable at all. But if it is dampened (has springs in it) you should have no problem with the stock Camaro flywheel. I think all the Camaro LT4 discs were dampened, while all the Corvette LT4 discs were rigid, but I could be wrong.
Jazsun
Dec 29, 2014 12:14 PM
mattszm6
Dec 14, 2014 07:09 AM
Bearmans
Dec 3, 2014 05:28 AM
Jul 4, 2005 05:00 PM
