LT1 T56 stock flywheel question
Old Aug 21, 2010 | 01:12 AM
Rob94hawk's Avatar
Just pulled my engine the other day and this is what my clutch looks like after sitting for 10+ years:
1. Do you think I could get away with resurfacing the flywheel and then buying a stock or aftermarket pressure plate and disk?
2. What's the stock clutch torque rating? Doing an LE2 heads/cam upgrade
I appreciate any advise you can give me. Thanx
Rob
Old Aug 21, 2010 | 03:15 AM
Procharged94Lt1's Avatar
Hard to tell- but as long as its only on the surface you should be just fine. Try and take some steel wool to it and see if it shines up. A re-surface shouldn't hurt anything since you have it out anyway.
There are many clutch options out there and depending on what you plan to do with the car a stock replacement should do pretty good for you. You can spend anywhere from a couple hundred on a clutch all the way up to over a grand- your pick.
Old Aug 21, 2010 | 03:17 AM
Old Aug 21, 2010 | 08:55 PM
Rob94hawk's Avatar
Other than some rust the disk looks in pretty good shape.
Anyone recommend a decent pressure plate?
Old Aug 26, 2010 | 07:58 AM
white97T/A's Avatar
For a low cost replacement, a LT4 PP and stock LT1 disc works well - for a street car.
Old Aug 30, 2010 | 08:52 PM
Rob94hawk's Avatar
Thumbs up
Got the flywheel resurfaced. One less thing I have to worry about:
Old Aug 30, 2010 | 11:18 PM
Looks good- pretty cheap to do while the flywheel is out and good insurance like you said to have one less thing to worry about.
oldschool
Feb 9, 2016 09:21 PM
cmdeshon
Jan 4, 2015 11:15 AM
cmdeshon
Dec 27, 2014 10:06 AM
Brandon Wittmer
Dec 20, 2014 09:51 PM
TheGreenZ28
Exhaust System
Dec 6, 2014 10:23 PM
