LT1 slave cylinder install question...
Old Nov 17, 2007 | 12:32 AM
droptop z's Avatar
Im gonna be replacing the clutch master/slave assy in the morning, I checked previous threads regarding the plastic strap going to the end of the actuating rod on the slave cylinder. So what is it's purpose? I've read that it is there to "break" the first time you use the clutch pedal and another, to keep the rod straight. I just want to know so that way I can do it the right way the first time.
Old Nov 17, 2007 | 03:36 AM
missetti's Avatar
Just align everything, cut, and bolt on.
Old Nov 17, 2007 | 02:00 PM
88irocz28's Avatar
The plastic strap has multiple purposes. It makes assembly easier since you don't have to push on the rod while bolting the cylinder on. It also helps with bleeding the hydraulics since the fluid has to originally fill up a much smaller space with the piston pushed all the way back in. Once you bolt it on and gravity bleed the hydraulics, all you have to do is push the clutch pedal in to break the straps, and voila, clutch is ready to go with minimal mess and spillage
Old Nov 17, 2007 | 04:49 PM
OBE1 95Z28's Avatar
The directions that come with the master/slave assembly instruct you to leave the strap in place.
HectorM52
Jul 30, 2017 11:46 AM
oldschool
Feb 9, 2016 09:21 PM
siguy
Nov 27, 2014 10:07 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
