lt1 flywheel question
Old May 7, 2007 | 11:58 AM
v8 FC's Avatar
OK i am doing a auto to manual conversion on my lt1 motor. now i have everything i need but the pigtails for the vss and rev. lock out and all that good stuff. i was going over everthing i got in my setup and i noticed that my flywheel is in good shape but i went to screw the clutch bolts in and one of them never stopped turning. i wanted to know if i took it to the machine shop (again) will they be able to fix that problem or is the flywheel shot?
Old May 7, 2007 | 05:10 PM
seawolf06's Avatar
Should be able to helicoil it if it's a stock flywheel.
Old May 7, 2007 | 07:54 PM
ablackcamaro's Avatar
I just finished the same conversion. The only pigtails you really need to worry about are the vss and the reverse lights. The reverse lockout solenoid already has a spring in it that requires enough pressure to get the tranny into reverse that there's no real need to wire it up. And the skipshift.. who cares
What clutch did you decide to go with? What other mods are done to the car?
Old May 7, 2007 | 08:22 PM
v8 FC's Avatar
lol what haven't i done. its a 88 mazda rx7 with an lt1 in it and i went with the a4 because it was rebuilt to handle 500 hp and its has a shift kit but man i can't stand not having my clutch anymore! so all i need is the vss and reverse light pigtails thanks man
oldschool
Feb 9, 2016 09:21 PM
cmdeshon
Dec 27, 2014 10:06 AM
mattszm6
Dec 14, 2014 07:09 AM
TheGreenZ28
Exhaust System
Dec 6, 2014 10:23 PM
Camaro90RS
Jul 23, 2002 07:57 AM
