LT1 Flexplate Bolt Question - Help
I have a TCI flexplate I would like to swap in when I change my converter. I am looking for the correct ARP Bolts for this flexplate, but there are two types listed for GM:
Internal Balance - 3/4 socket UHL .680 7/16-20
External Balance - 5/8 socket UHL .725 7/16-20 (1Pc. Rear Seal)
I am assuming I need the External balance with 1Pc. Rear Seal, can someone verify this for me? I called ARP and the guy was like "Uhh, I only show two kinds for the chevrolet....."
Also, has anyone had any interference issues with ARP Bolts. I have a friend in my car club who's converter bolts actually hit the back of the motor when installed.
Thanks,
Ken
Thanks,
Ken
I had the ARP bolts w/ the large 12 point heads and there was a bolt head clearance problem with the crank hub (no room for the socket). So, I went back with a new set of OEM (GM) flex-plate bolts w/ thread-locker.
Also, make sure your TCI flex-plate isn't powder-coated. If it is, you'll need to sand down the coating on both sides of the plate to ensure the coating doesn't crush under the torque load and the plate become loose. That has happened to several people.
WD
WD
Thanks for the tip, I will check on the OEM bolts.
So basically both sides of the flexplate where it is bolted to the crank, and where the converter bolts are located the powdercoat should be ground?
Wow, thanks for the pictures, I will definatley be removing the powder coat off those areas. I hope it isn't too difficult, I don't have a grinder, just a orbital sander or a dremel tool.
Lt1son
Dec 31, 2014 01:35 PM
Jul 4, 2005 05:00 PM
