limited slip rear end one wheel??
Turned the corner after a stop at stop sign,, hammered it down hard and got right wheel spinning like a mad ***** with mega smoke.
Question is (1993 Z28 with 2.73) will our rear ends let out a one wheel burn out?? I laid a patch about 50 feet long before letting off.
Re: limited slip rear end one wheel??
Just answered that in the "Broken Posi??" thread. It probably means some broken springs on one side of the LSD. Mine did 1 wheel peels turning right, posi straight and turning left.
Try changing your read end fluid (Use just dino oil and real GM Limited slip additive) and see if that works first. The fluid/additive can and does wear out over time and mileage.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
