LCA"s
Good choice, I hope you got them with the poly/poly setup. If your car is not lowered, you probably do not need them (mine is stock height, and I did not). After the install, if the LCA's are parrallel (sp), or pointing slightly down on the axle side, you are o.k., if they are angled up on the axle side, you will need the relocation brackets to lower the angle.
SteveC
SteveC
The relocation brackets will also help reduce/eliminate squat on launch which will give you better traction,resulting in better launches.If you aren't racing the car then it really doesn't matter,in fact some people like the squat because of the way it looks.
