Just installed 4:10s: Excessive whine when turning: plz HELP!
So i just got done installing richmond 4:10s in my TA. They whine at low rpms, but when you turn right, either a sharp turn or even going around a curve, they make this god-awful-ear-piercing-howling noise. What could be the cause of this? I installed new bearings (except axle bearings) and used asolid pinion spacer if that makes any difference. thanks
Re: Just installed 4:10s: Excessive whine when turning: plz HELP!
not sure if this is a common problem when turning , but my buddies 4.10s do this to
high gears like that do whine alot tho
Did you set the backlash correctly? This would be my first guess, and might turn into a bigger problem than just a high pitched whine =/
i believe the backlash is correct- it was about .008 and it called for .010 +/- .004 . im going to tear it apart today and reset everything. i just wasn't sure why it would make the real loud noise when just turning right- i thought maybe that had to do with something specific and someone would know
Originally Posted by anaik
Isn't turning noise caused by not having added friction modifier?
problem solved. i took the cover off the rear this morning and noticed that there was a little play left and right. i reshimmed the carrier bearings to fix the slop, rechecked the backlash, (set at .006) and everything is a- ok
