i have a different auto then everyone...
Old Oct 12, 2004 | 06:46 PM
Sceanzo's Avatar
all the automatic LT1's i have seen have this on the shifter
Park reverse overdrive, non overdrive, 2 , 1
my LT1 is the only one i know that doesn't have the 1 on it.
it goes to two and there is nothing after that, does anyone else have this or am i just a freak
Old Oct 12, 2004 | 06:49 PM
94blackz14.2's Avatar
Re: i have a different auto then everyone...
I am pretty sure that means that you have a 2.73 rearend.
Old Oct 12, 2004 | 06:56 PM
Sceanzo's Avatar
right
so what do kind of other rearends to the other ones ive seen have
and which one is better?
Old Oct 12, 2004 | 07:04 PM
The other rearend that comes stock in the A4 cars is 3.23. The only difference, I believe, in the shifter is that there is a selection for 1st gear.
Old Oct 12, 2004 | 07:42 PM
ABA383's Avatar
If you want access to first gear, pull the console and look at the shifter gate. On the passenger side there is a little plastic stop molded into the plastic shifter gates that prevents the shifter from going back into "1". Hacksaw, cut, file it off and you can now pull the car down into first...fyi..and yes not having a 1 means you have a 2.73 rear gear...
--Alan
Old Oct 13, 2004 | 01:10 AM
94ZRiCeKiLr's Avatar
--Alan
yep, the shift linkage is the same inside the tranny, it's jsut the stop.
also, the "no 1 = 2.73" rule seems to only be true in the LT1 years. My 98 Z was originally a GU2 (2.73) car and it's got the 1.
Parts Wanted
May 1, 2016 10:25 AM
drt
Sep 27, 2015 04:39 PM
Matt Dreessen
Sep 9, 2015 09:58 PM
scottcba1
Sep 8, 2015 09:52 AM
tdigger9899
Sep 7, 2015 10:56 AM
