how to remove trans????
hello guys well im getting ready to take my tranny out to get rebuild. my question is this process deficult to do does any one have a how to install and remove the tranny instructions or something??? on my 94 z28 4l60e...if you can please help me..thanks
Re: how to remove trans????
I like to show people Javier's TC install writeup, just get the car up a little higher to actually get the tranny out from under it...
Originally Posted by OneFreakZ
hey there's no pics??????
Re: Hope comments and pictures help.
I just got done doing my 1994 Z-28 (clutch and rear main seal). Not too bad of a job. I have a Chilton and Haynes manual...either one would be a good source. The only hang up I had was my first attempt at pulling the tranny off the bell housing. The fork must be pull back to disengage the release bearing. Neither manual was very clear on that. Just grab the clutch release lever, with plyers, and pull. It will come loose and stay with the tranny. Take the tranny off of the bell housing, then remove the bell housing (if you want to get to rear main). The second bolt down on the left of bell housing is a little tricky. Not much room to get a 14mm wrench on it. The rest just use a long extension and a socket.
PS I am not a mechanic
Hope this helps a little. It took me an entire 2 days, however knowing what I know now I could do it in a full day ez. Hope the pics help.
GA93FORMULA
Jul 24, 2002 11:38 PM
