How to remove my 10 carrier???
Old Feb 28, 2010 | 12:42 AM
fastlt1camaro's Avatar
Ok so I want to put a posi carrier in my rearend I got everything out of the rearend but I cant get my old carrier out what do I need to do???
Old Feb 28, 2010 | 07:39 AM
AL SS590 M6's Avatar
Moderator
You have the bearing caps off? Then you just have to put a prybar behind it and pop it out. It'll be stuck. If you're working alone under the car, put the bearing caps back on loosely to catch it for you when you pop it loose.
Old Feb 28, 2010 | 11:25 AM
Really I'll give that a try I am just scared I will break somthing THANKS
Old Feb 28, 2010 | 10:41 PM
budgetlt1's Avatar
easiest way is to put a wrench on one of the ring gear bolts, then rotate the carrier upwards until the wrench is againt the diff housing. now you can easily pry on the bottom of the carrier w/out it turning and it will come out. make sense?
greenzee28
Sep 25, 2015 04:29 PM
Jake Bialke
Sep 24, 2015 11:31 AM
wbspoon
Sep 19, 2015 08:12 AM
NewsBot
Sep 14, 2015 09:20 AM
RX Speed Works
Sep 11, 2015 03:31 PM
