How much am I leaving on the table?
Old Sep 20, 2007 | 09:23 PM
z28_theantirice's Avatar
I know I need a stall and some gears for my setup but how much am I leaving on the table by running a stock stall and 3.23's ? Mods in sig
Old Sep 20, 2007 | 09:27 PM
Z-RATED94's Avatar
Do you have any 60ft. times to go by, it would help give you an idea on how much you might pick.
Old Sep 20, 2007 | 09:28 PM
Nada, no local track
Old Sep 20, 2007 | 09:30 PM
Z-RATED94's Avatar
That's to bad. But on average, a good converter with some 3.73s will cut your et half a second, IF you can hook.
Old Sep 21, 2007 | 07:20 PM
96capricemgr's Avatar
There are three tracks in this state, where are you at I can tell you which is closest.
Old Sep 21, 2007 | 07:30 PM
25 minutes north of Madison
Old Sep 21, 2007 | 08:37 PM
lethal93ta's Avatar
with a heads and cam in the car your leaving a lot out there, you need to get the RPM up. theres an easy .5 there IF you can get the car to hook after you put a converter and gears in there, you dont have any chassis work listed in your sig.
WobblySausage
Oct 7, 2015 10:09 AM
Bigtoyz97
Sep 21, 2015 01:44 PM
98-LS1Z28
Sep 8, 2015 03:12 PM
Bails098
Aug 17, 2015 05:15 PM
Aug 17, 2015 09:50 AM
