How i removed the pilot bushing
Old Sep 10, 2006 | 02:20 AM
b4cz2896's Avatar
I couldn't get the pilot bushing out of the crankshaft using the conventional methods (grease with a socket/ slide hammer with the pilot bushing removal tool) so i went and bought a 1" bi-metal hole saw from home depot and drilled the bushing out. I was carefull not to damage the crankshaft and was able to remove it fairly easily. I think this may help anyone who is having problems getting there pilot bushing out.
Old Sep 10, 2006 | 03:05 PM
rpm4lalo's Avatar
Re: How i removed the pilot bushing
I used the wet toilet paper method, worked great.
Old Sep 11, 2006 | 08:53 PM
97formulakid's Avatar
I just used a pilot bearing puller, I don't think it gets any easier than that.
Old Sep 11, 2006 | 08:56 PM
NoRiceInside's Avatar
nope! gotta love snap-on.
Old Sep 11, 2006 | 09:25 PM
Actually I just rented it from Advanced Auto Parts. I know the guys that work there so I just went and "borrowed" it and took it back when I was done. Took me about 5 min to get it out and I didn't get grease all over the place trying to hydraulic it out.
Old Sep 11, 2006 | 09:45 PM
5.0THIS's Avatar
I found a bolt with an outside diameter just big enough to thread through the bushing and push it out. easy
Old Sep 18, 2006 | 07:18 PM
b4cz2896's Avatar
I tried the tool from autozone and snapped one of the fingers right off the tool while i torque down on the spreader. Still got my money back for the pos tool, but the bushing was still stuck. My bearing was pressed in flush with the back of the crank hub and the jaws on the tool had nothing to grip. maybe autozone just has crappy rental tools.
Old Sep 18, 2006 | 08:26 PM
anaik's Avatar
Good idea. The one time I had trouble, an older different car, I used a sharp chisel and split it all the way down then used a screwdriver to fold it in, that made it loose.
Old Sep 18, 2006 | 08:27 PM
wrd1972's Avatar
Same here. No renting or buying tools. Just popped right out in 2 minutes or less.
Old Sep 26, 2006 | 11:14 PM
Josh'95Z28conv's Avatar
The autozone tool works fine. Ive used it many times with zero problems.
LMAO at your avatar Lalo. Its fitting
Old Jun 9, 2007 | 03:41 PM
RPWS6's Avatar
I just split mine in about 10 minutes using a chisle. Not to bad.
Old Jun 9, 2007 | 10:52 PM
2000slp2768's Avatar
I used a bearing puller. I was told that there is a plug behind the pilot bearing on the crank. If you use the grease method you can actually push the plug out and oil will just flow out if the crank. Dont know how true it is but thought I would share.
Boss002
Jan 20, 2016 12:17 PM
realistyc
Jul 28, 2015 07:32 PM
RX Speed Works
Jul 24, 2015 02:25 PM
Dark Zeiro
Jul 19, 2015 08:25 AM
Jul 17, 2015 02:47 PM
