How hard to replace a driveshaft???
Old Oct 2, 2003 | 07:48 PM
Knowklew's Avatar
Question How hard to replace a driveshaft???
Well since my car has a steel driveshaft i was thinking of swapping in an aluminum drive shaft and probably a shaft loop too since i will have it off...anyway, how hard is this to do?
Old Oct 2, 2003 | 07:54 PM
Rodrigues's Avatar
Depends on what loop and about 10 minutes to change the driveshaft, just 4 bolts.
Old Oct 2, 2003 | 09:07 PM
morb|d's Avatar
cake.
Old Oct 2, 2003 | 10:40 PM
madwolf's Avatar
Four 11mm bolts. Just place a jack underneath the rear-end and jack the car up. First, remove 2 bolts, then switch it in neutral, turn the wheels a little bit, and remove the other two. Then you might need to use a bigger screwdriver or something similar to pry against the yoke to push out the u-joint.
Old Oct 2, 2003 | 10:56 PM
Make sure your your car can't move (wheels blocked) before removing the driveshaft. It's helpful to have the rear wheels off the ground, so you can turn the pinion (that way you can rotate the driveshaft and get to all the nuts). Block the front wheels. Put it in gear or park when you need to keep the driveshaft still, neutral when you want to turn it.
Old Oct 3, 2003 | 08:54 AM
GUMP's Avatar
Make sure that you use jack stands to support the car. It would really hurt if you dropped it on your head!!
Good Luck,
Daren
HectorM52
Jul 30, 2017 11:46 AM
blac94Z
15
Mar 2, 2015 12:00 PM
ddr698
Jan 31, 2015 10:58 AM
Jazsun
Dec 29, 2014 12:14 PM
