How to flush the clutch fluid???
Old Oct 31, 2004 | 02:47 PM
HardcoreRM125's Avatar
I think my Slave Cylinder is screwing up, causing problems shifting my car. I was checking it out, and noticed the clutch fluid line goes 1/4 away from a header primary, so I think it boiled the fluid. The fluid is all dark brown and gross colored now. What is the easiest way to drain out ALL the old fluid, and then bleed the system as I add fresh?
Old Oct 31, 2004 | 02:59 PM
jonota's Avatar
Re: How to flush the clutch fluid???
Remove the master and slave cylinder as an assembly. There are push pins on either cylinder that connect the hydraulic line. Remove these. Drain the system. Flush with new hydraulic fluid until it comes back out clean. Reconnect to car. Refill system with slave cylinder disconnected, and every once and a while work the slave cylinder back and forth to remove bubbles. Once you work it about 10 times in and out and get no bubbles, and reservoir level is high enough, reconnect the slave cylinder to the bellhousing and you're done.
Jonota
sleeperZ96BT
Sep 9, 2015 08:28 AM
sherwinZ28
11
Aug 15, 2015 05:38 PM
karpetcm
Aug 14, 2015 03:02 PM
dolfan324
Jul 17, 2015 10:34 PM
Noct
Jul 14, 2015 01:18 AM
