how do i disable traction control
Old Mar 8, 2007 | 06:25 PM
cr8tive ta's Avatar
just like the title says, i got but i dont want it.
95 trans am lt1, any ideas.pm me.
Old Mar 9, 2007 | 01:23 PM
1SlowFormula's Avatar
Are you looking to remove it or just have it default to off rather then on?
Old Mar 9, 2007 | 02:24 PM
rskrause's Avatar
Moderator
Hit the switch! If you want to permanently disable it it can be done in the PCM. And there is some other way involving replacing or reversing the switch. I just can't seem to recall the details (senility is a bitch). But if you do a search you will find it. It has been discussed here.
Rich
Old Mar 16, 2007 | 03:12 PM
vdubois's Avatar
Or you could just unplug one of your wheel sensors. That disabled the crap outta mine.
Old Mar 17, 2007 | 08:45 AM
respectirocz's Avatar
disabling the speed sensor will probably disable the ABS as well as the traction control
do you want to disable traction control only?
Old Mar 17, 2007 | 12:36 PM
turnin20s's Avatar
Heres what you will need if you still want ABS and get the ugly black box off the drivers side valve cover. Part #s for the cables are a few posts down...
http://web.camaross.com/forums/showthread.php?t=506043
PopoFormula
Oct 12, 2015 04:19 PM
68camaroboltz
Oct 5, 2015 01:46 PM
Louey
Pacific
Oct 1, 2015 12:37 AM
Stephen68
Parts Wanted
Sep 27, 2015 06:42 PM
drt
Sep 27, 2015 04:39 PM
