How to check Driveshaft Angles?
Old Sep 12, 2007 | 01:58 PM
Bersaglieri's Avatar
What tool and operation do you use to check your pinion angles? I have a BMR Trak Pack and am actively fabricating the transmission mount for my 4L80E. I want to make sure I get the angles of the driveshaft right. I heard the one you get from BMR or SLP [the little dial ones] are horrible and wanted to know how everyone else was doing it. I can shim the tranmission as much as needed and adjust the rear two ways. Thanks.
-Dustin-
Old Sep 12, 2007 | 02:25 PM
87DJP2001's Avatar
Angle gage from any hardware store. It will show degrees & minutes. Youi do not need a special or expensive gage.
Old Sep 12, 2007 | 09:04 PM
What are the angles you guys are using? What's the driveshaft angle? I know to keep the from and rear within 1* of each other, but I also know not to make each more than 3* overall.
-Dustin-
Old Sep 13, 2007 | 12:05 AM
tapout911's Avatar
Copied from the instructions from my UMI chassis mount TA:
Place the angle finder on the driveshaft and record the angle. Now place the angle finder on the bottom plate of the torque arm where it attaches to the rear end, record this angle as well. To achieve true pinion angle you must add the two measurements together. For example if the driveshaft measures 0 degrees and the TA measure -1 degrees, you have a -1 degrees of pinion angle.
Hope that helps, I was in the process of doing this and had the instructions handy.
teal98
15
Sep 16, 2002 01:23 PM
danielbmx
Aug 27, 2002 11:11 PM
kev93z28
Aug 19, 2002 12:48 AM
johnsocal
21
Aug 17, 2002 01:06 AM
SilverWS6
13
Aug 14, 2002 09:29 PM
