how can I bypass the computer shifting?
Old Aug 29, 2007 | 08:55 PM
9formula4's Avatar
Is there any way without going full manual or adding a shift kit to bypass the computer controlling shifts? I would like to be able to make it shift because right now when I am on it it will not shift correctly and usually results in bouncing off rev limiter and I fear the problem may take the lives of the valvetrain components.
If anyone knows any way to do it please let me know.
Old Aug 29, 2007 | 09:28 PM
dangalla's Avatar
thats a really good sign the trans is on its way out and you may want to start thinkin about a rebuild rather than a way to controll shifts
Old Aug 29, 2007 | 09:51 PM
9formula4's Avatar
I am going to rebuild it SOON but I was thinking until then. Oh well I guess it will be sooner than planned
Old Aug 31, 2007 | 04:28 AM
30696bird's Avatar
Well, if you have to pull the transmission, put a TH350 in the car. That solved my PCM shifting problems!
Old Aug 31, 2007 | 08:13 AM
dangalla's Avatar
yeah that will also solve that silly problem of the car shifting into 4th and saving you gas
Old Aug 31, 2007 | 04:17 PM
30696bird's Avatar
With the mods I have...........I quit caring about fuel mileage LONNNNNG ago!
Old Sep 1, 2007 | 08:27 AM
reocamaro's Avatar
Don't they make skip shift eliminator for automatics? That should work right?
Old Sep 1, 2007 | 08:42 AM
Performabuilt's Avatar
Supporting Vendor
Well you could build some sort of shift box and plug it directly into the trans we have one I built for testing purposes, Basically its three toggel switches two control the shift solenoids and 1 for the tcc. Ours also have a presure control but if you were only using it for wot racing then it wouldnt be needed. Just and Idea ,
Old Sep 1, 2007 | 09:38 AM
reocamaro's Avatar
My trans only has a couple thousands miles and seems to do the same thing that the OP stated. I think it's in the tuning. Is the OP's car relatively stock?
Old Sep 1, 2007 | 09:35 PM
Supporting Vendor
If the trans is in good shape then likley its a matter of tuning , Particulary with mods to the engine the RPM rises faster but the time it takes the trans to shift from one gear to another is a constant. So depending on when you have it set to shift there may not be time to complete the shift before it hits the limiter
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
HarleyZ28
Oct 5, 2015 06:23 AM
PROJECT X
Apr 17, 2015 12:13 AM
