High Stall No 1-2 Shift Manual Valvebody?
Can you get around the high stall no 1-2 shift if you use a manual valvebody? I hear pcm 4 less has a fix for it and Ed Wright also is this true? With a standard 4l60E trans, if you hold the shifter manually in 1st and then shift to second manually, will it still skip 2nd gear without a manual valvebody?
Thanks,
Chris
Thanks,
Chris
james007moore
Jan 1, 2016 01:14 PM
jb4xx
Feb 2, 2015 10:00 PM
