High RPM Vibration
Old Nov 17, 2006 | 07:56 AM
  #16
Sweetred95ta's Avatar
Originally Posted by TA-Body
I was under the impression the input shaft always turned.
How would you get it in gear if the input shaft was turning? Think about it, with a clutch assembly, the only thing that grabs the input shaft is the clutch. It is the only component that has splines. The tip of the input shaft sticks into the back of the crank, but there is a bearing there (be it brass or roller, either way, it doesn't grab the input shaft). When the clutch is disengaged, it is not spining, therefore neither is the input shaft.
Apr 16, 2015 09:57 AM
BigWil
Mar 29, 2015 12:24 PM
Rde Bandit
Mar 21, 2015 10:17 PM
mattszm6
Dec 14, 2014 07:09 AM
PhantomTA
Aug 17, 2002 12:19 AM
