help turbo 350
Old Oct 22, 2004 | 08:06 PM
spinout's Avatar
help turbo 350
first and second gear there but no third possibly modulator valve????
fast reply please
Old Oct 22, 2004 | 10:14 PM
n2ceptor's Avatar
Re: help turbo 350
http://www.roversd1.com/modulator_as..._diagnosis.htm
Hope this helps...
Old Oct 23, 2004 | 09:29 PM
spinout's Avatar
Re: help turbo 350
replaced modulator valve checked governer still no third gear and second gear only works if i shift manualy what couldit be???
Old Oct 23, 2004 | 09:46 PM
n2ceptor's Avatar
Re: help turbo 350
Sticking valve in valve body?????? Low pressure????? Low fluid level will keep it from shifting....
Old Oct 23, 2004 | 10:22 PM
spinout's Avatar
Re: help turbo 350
where would I find some info on the shift paterns and power flow through the trany so I can figure out which valve may be stuck the fluid level is up and the pressures should be good the trany only has 89'00 kms on it.
Old Oct 23, 2004 | 10:54 PM
n2ceptor's Avatar
Re: help turbo 350
My information is limited on transmissions.... I usually search web sites like http://tciauto.com/tci.htm to find information... "Search Engines", like goggle works wonders... I e-mail some companies, some reply back and some dont.... Hit and miss there.... Or I know shops that specialize on certain things, and I just stop by/call, and get information that way....
I looked around on the net, but couldnt find anything close to help... Maybe someone with knowledge on transmissions will buzz in..... Good luck...
EDIT: Found this forum.. Might search and ask here....
http://www.gmperformance.org/
HAWG
Sep 25, 2015 11:41 AM
95blkss
Sep 22, 2015 03:18 PM
cmsmith
Sep 14, 2015 09:09 PM
sleeperZ96BT
Sep 10, 2015 08:01 AM
