Help!!!!
Old May 20, 2007 | 01:46 AM
gpss97's Avatar
Help!!!!
ok its almost two in the morning....and earlier today my clutch start making a lil noise..almost like a squeeling noise..
well i left to go somewhere earlier and when the pedal is all the way to the floor i could hear and feel a clanking sound. then shortly after that it would try and kill the car with the clutch all the way in.
well now if i put the clutch to the floor to try and start it..its like trying to start it in gear? i'm three hours away from home..and have to drive back tomorrow...
anyone have an idea or heard of something to this similar happen?
thanks
mike
Old May 20, 2007 | 01:47 AM
gpss97's Avatar
help
oh and the pedal is also really hard to push in now..if that helps
Old May 20, 2007 | 02:06 AM
Performabuilt's Avatar
Supporting Vendor
Well it sounds like either your presure plate failed or you slave cylinder . Start car in gear you want to drive in 2-3 and try to avoid stops . As long as your starter hold out you should make it. I have been there and done that .
Old May 21, 2007 | 07:12 AM
gpss97's Avatar
well i got under there and found out what it was. it was the bolt that holds the clutch fork on....well it was a pain in the *** getting the bolt tightened enough to hold it in place..cause it was getting dark on me.
