harsh shift
Re: harsh shift
there is an accumulator on the valve body that cushions the shift from park reverse or neutral to drive .it is possible the spring has broken or that line pressure is too high at idle foor some reason,take a line pressure reading,if it high diagnose as per factory manual.if its normal ,remove the accumulator cover and inspect the spring
WobblySausage
Oct 7, 2015 10:09 AM
