Going to rebuild my rea end...
I have decided to go for the gold here and rebuild the rear end with some heavy duty parts.
All new,
Carrier Bearings
Pinion Bearings
Pinion Nut
Pinion Seal
Preload Shims or
Crush Collar
Pinion Shims
Gasket or RTV
Loctite
Marking Compound
Adjustable Differential Shims
(Where applicable)
Oil Slingers
(Where applicable)
Ring Gear Bolts
(Included in select kits) and new 27 spline axels and bearings etc.
Please no rants on the lousy F-Body rear ends, I don't need a 12 bolt or a Ford 9" for a daily driver that almost never sees the track. Total cost for parts including an OEM 3:73 ring and pinion will be $500. This will give me a totaly new and stronger rear end. I may replace my posi traction unit as well.
__________________
All new,
Carrier Bearings
Pinion Bearings
Pinion Nut
Pinion Seal
Preload Shims or
Crush Collar
Pinion Shims
Gasket or RTV
Loctite
Marking Compound
(Where applicable)
Oil Slingers
(Where applicable)
Ring Gear Bolts
__________________
