gear selector problems
i just got done installing a new torque converter and transgo shift kit. when i got everything back together the trans doesn't want to go into park reverse or neutral every gear is forward. i like that kind of attitude but sometimes you do need to go backwards.
also the car seems to start out real slow like it was in 3rd gear even when i get on it a little but then it shifts twice so i guess it does start in first?!? I thought it was the selector but it seems to only go on one way to the cable. anyone know what would cause this?
Re: gear selector problems
I'm not sure but I will help you get this to the top again,
All I do know that could play a factor in this is when you pulled the VB to install the TG kit you messed something up!
Sorry not too much help, but hopefully someone will chime in!
Sarahrope64
Nov 27, 2014 11:17 AM
