Gear Question
Old Mar 3, 2004 | 06:20 PM
ZYAPONY's Avatar
Gear Question
My buddy has a '99 Z bone stock. Off hand, does anyone know what gears came with that model year? Thanks!
Old Mar 3, 2004 | 06:30 PM
redzsmoked212's Avatar
Well that depends on the cars specs now if its a manual trans it came with 3.23.auto trannys came with 2.73, ss/ws6 models all came with 3.42 except autos hope that helps.
Old Mar 3, 2004 | 06:52 PM
1stls1's Avatar
My 99z28 came stock w/ 3.23 auto
Old Mar 3, 2004 | 09:11 PM
Capn Pete's Avatar
- 6 speed = 3.42's, no option
- automatic = 2.73's or 3.23's ............. in this case, check the sticker on the driver's side door for a code GU2 or GU5.
- GU2 = 2.73's
- GU5 = 3.23's
- GU6 = 3.42's (for the 6-speed guys)
Old Mar 4, 2004 | 09:59 PM
1stls1's Avatar
just off the beatin path, what could I expect from going from 3.23 to 3.73 gears.I hear its almost like adding a super charger.
Old Mar 5, 2004 | 05:05 AM
id say with good tires (nitto drag radials) .4-.7 off et times
Old Mar 5, 2004 | 01:23 PM
Capn Pete's Avatar
No, unfortunately it's not like adding a supercharger! I went from 2.73's to 3.73's last year, and while YES it pulls way harder off the line, I did NOT run like I had a supercharger. At the track I ran the exact same time (13.4) and actually 1 mph slower. Problem being, the added gear made me realize how $h!tty my tires were. If you're only going from 3.23 to 3.73, that's not a very big difference, so you wouldn't even "feel" the same difference I did going from 2.73's.
Old Mar 5, 2004 | 03:04 PM
thats bogus if you work on the rear suspension and jump to a 3.73 your deffinetly gonna see better times. i through a 4.10 in and had to buy new tires,and through new rear end suspension mods in there now that gear was a jump from the 2.73 i had originally and it puts me at .6-.8 better 1/4 mile time
Old Mar 6, 2004 | 07:05 AM
1stls1's Avatar
what kind of rear sup parts are you talking about,TA and LCA,will these mods or the mods you are talking about hert in auto cross racing?i am going to go to 315 in the rear soon(not soon enough).i was told to do my tconverter when i'm done w/ gear changes and the like b/c they tailer make it to the mods you have,true?
Old Mar 6, 2004 | 10:49 PM
Capn Pete's Avatar
I think I would have seen gains like that if I had put good tires (DR's / ET Streets) on the car last year. However, I was running on the factory original 245/50/16 Goodyear Eagle RSA's ( ). The damn things would spin from a dead stop to half-way through 2nd gear!!
ChrisFrez
Feb 15, 2015 07:49 AM
ChrisFrez
Feb 1, 2015 08:26 AM
ChrisFrez
Jan 25, 2015 08:06 AM
ChrisFrez
Dec 21, 2014 09:47 PM
ChrisFrez
Dec 15, 2014 03:09 PM
