Ford 9" Question
Old Sep 14, 2003 | 02:58 PM
Gripenfelter's Avatar
Ford 9" Question
How do you tell if a Ford 9" has 31 spline axles without ripping it open?
I know some pre-72s had them
Anything out of the ordinary I have to do to make it fit a 4th gen?
I'm cutting my tubes off and welding them to the Ford 9" and fabricating a bracket for the torque arm.
What about the ABS sensor? How do I keep the light from coming on?
Old Sep 14, 2003 | 09:03 PM
TravisA's Avatar
Sorry i have no answer but a question for you.
Are you cutting the axle tubes off of your 7.5 and welding them to the 9"?
Travis
Old Sep 14, 2003 | 09:14 PM
Z95m6's Avatar
At the end of a set of 31 spline axles right dead center of the axle in between all the studs the axle will be flat and have two holeds drilled in it. On a set of 28 spline axles in the center between all the studs there will be What people refer to as an ice cream scoop because there is a cut out in the shape an ice cream scooper makes. Here is a website but it doesn't show pics you should know when you look at a set though. I knew there was a good reason i got that 428 Mach 1 at home.
http://dfwmotorsport.com/Fairlane/9inchrearends.htm
Also if you want ABS refer to my post below.
ChrisFrez
Dec 15, 2014 03:09 PM
ChrisFrez
Dec 7, 2014 06:01 PM
NewsBot
Dec 3, 2014 12:30 PM
ChrisFrez
Nov 30, 2014 08:41 AM
ChrisFrez
Nov 23, 2014 10:33 AM
