Finishing clutch install, a few questions ASAP!
I have a new rear main seal but wanted to double check on installing it. Can I just pry out the old one and then smack the new one in with a piece of wood or something?
What is the trick again for removing the pilot bushing? *yes mine has a buching in it.
Is there anything special I need to do with the clutch fork, it seams straight forward.
Other than that I assume its just align everything, bolt it up, bolt on the bellhousing and then bolt on the tranny. Let me know if I am missing anything guys.
Thanks,
Eddie
Thanks,
Eddie
Re: Finishing clutch install, a few questions ASAP!
Thanks,
Eddie
Thanks,
Eddie
Make sure the rod dosnt come out of the bore on your slave cylinder, your pedal will Never feel the same unless you replace it.
Good luck.
Another way to get out the pilot bearing is to pack wet toilet paper inside the bearing and use either a 3/8 or a 1/2 inch ratchet extention (I can't remember which) and keep packing it in till it pops out.
ro2207
Dec 4, 2014 06:18 PM
Jul 4, 2005 05:00 PM
