F-body 4L60E in Truck
Just was wondering if it is possible to use the A4 from my 94 Formula in a 96 fullsize two wheel drive truck. Other than changing the tailshaft, is there anything else that will need swapped or will it just plain not work? I've searched threads and seen about swapping wiring harnesses and reprogramming pcms and all that, but not real clear on what I'd have to do to go from car To truck as all the ones I seen were asking about opposite. Thanks in advance.
(am converting the Bird to an M6 anyway)
If you're using a small block chevy engine then it will bolt up. But as for the fitting, pcm, wiring, blah blah blah, that's another story. If you wanted it to be as easy as possible you'd have to switch the engine out with it.
