easy petal
Old Dec 15, 2007 | 02:27 PM
Daniel6718's Avatar
easy petal
i had a new clutch/pp from o reilleys in my car its a valeo unit? and stock resurfaced flywheel, it was great car only has bolt ons and it never slipped...i was racing one night missed 3rd and went into 1st and the clutch disk blew up...took it apart and looked it over got a new clutch put it back together and the line for my clutch(steel braided) somehow got a cut in it...i replaced it bled the clutch by pushing in the slave rod several times...and by using a vacume brake bleeding pump with a pointed nipple on it i stuck into the slave resvoir(all the way to the hose at the bottom) and getting a more bubbles out but they never stopped comming and the petal never changed...
ever since this time(about 5k ago) my petal is very easy to push down...and the clutch will disengauge about 35% of the way down of the clutch petals travel...its really annoying although it doesnt slip id just like my clutch to engauge at the bottom of the petals travel...and not be soo easy to push, i have no idea what to do
also my clutch petal used to squeek loudly when depressing it...i gut under there with some wd-40 and sprayed its quieted down a lot but still does it...
and ever since the new clutch the t/o bearing makes noise i think...i can hear a tapping noise and push the petal in and it will stop?
Old Dec 16, 2007 | 03:43 PM
Hard to follow.... did you push the vacuum bleeder into the MASTER cylinder reservoir? If the vacuum pump was endlessly pulling bubbles up through the braided line, the air had to be getting into the slave or line somehow. Are you sure you tightened the line to the slave?
A soft pedal generally means air in the system.
Old Dec 18, 2007 | 12:09 AM
Daniel6718's Avatar
well i woulod pull a vacume on the slave master line at the bottom of it with a nipple pull a vacume then i wouldpush in the rod on the slave and i did this several several times and i couldent make it any better...i did get a bunch of air out of it though...you think i need to go further and try to get more air out??
CARiD
Sep 30, 2015 05:44 AM
Fatdog2
Sep 16, 2015 11:04 PM
NewsBot
Sep 15, 2015 11:53 AM
Daluchman1974
Sep 11, 2015 06:12 AM
themex2002
Sep 2, 2015 03:47 PM
