Easiest way to change a throw out bearing
Old Jun 6, 2006 | 03:23 PM
live4therush's Avatar
My throw out bearing is startin to make a knock so i need to change it, whats the easiest way, by pullin the engine up, or droppin the transmission down?
Old Jun 6, 2006 | 03:30 PM
DrewHMS97SS's Avatar
Re: Easiest way to change a throw out bearing
transmission down, you will need to remove the tranny.
Old Jun 6, 2006 | 03:38 PM
Birdman7389's Avatar
Definitely trans down....should only take a few hours.....
Old Jun 6, 2006 | 03:49 PM
fastchevy's Avatar
Might as well have the pressure plate turned (or replaced) and install a new clutch disk while your in there.
Old Jun 6, 2006 | 04:57 PM
Do you have to do anything with the subframe or is it just the transmission mounts and transmission bolts that have to go.
BigWil
Mar 29, 2015 12:24 PM
BPS
9
Mar 5, 2015 10:51 PM
grabbem88
Feb 17, 2015 07:49 AM
HectorM52
Jan 30, 2015 11:08 PM
