DriveShaft
Old Feb 13, 2006 | 11:22 PM
DontMixWithRice's Avatar
DriveShaft
Name all the parts of the driveshaft that may loosen up.
I have a weird noise coming from the driveshaft, and it sounds like it keeps on loosening up and hitting either my floorboard or the exhaust pipes.
I know its the driveshaft because the noise only occurs in motion. (its linked to a t-56)
anyways, i have to go under the car and take a look at it, but I would like to have an idea.
I know its loose because whenever i make a sharp turn itll start making a horrible noise. but when i make another sharp turn, apparently it jumps back into place and the noise stops.
thanks in advance/
-d
Old Feb 14, 2006 | 07:13 AM
teke184's Avatar
Re: DriveShaft
check all your mounts
trans, torque arm, lca
you'll probably have to remove the trans to inspect it, it's only a few bolts.
driveshaft shouldn't make noises only on certain turns.
Old Feb 14, 2006 | 09:52 AM
Re: DriveShaft
yeah...too bad its v-day....i cant go under my car...i have to spend time with my s.o.! dammit!
thanks for the reply.
Old Feb 14, 2006 | 09:53 AM
Re: DriveShaft
and mile marker 52, eh?!?!?
I have a house on 100.3...ive never seen you around, and i go to key west, or try to go, at least onece a month...
RUENUF
Mar 13, 2016 03:37 PM
Henson071
Dec 30, 2015 09:55 PM
ryanhilsgen
9
Sep 21, 2015 07:34 PM
95z_28_camaro_4_Ivan
Aug 25, 2015 03:59 PM
realistyc
Jul 28, 2015 07:32 PM
