Does this sound like a loose converter or slipping trans??
Hitting the revlimmiter about 10-30 feet before the traps and going through the traps at 117mph. Here is the set up. th350 b&m holeshot 3600 nitrous ready, 3.23 gear and 28inch tire. I know i should not be that high on the tac with that set up. Trans makes wierd noise and feeling on 2-3 shift on nitrous but fine on motor runs.
thr converter should go into a vortec flow where the fluid rotates in a spiral motion inside the converter and obtain fluid coupling
so basically at high rpm you shouldnt be stalling anymore but anything is possible i guess. but id look at the tranny
What sucks is the trans was built early this spring to hold an estimated 650hp, but i was never given a torque spec for it. Trans is killer out of the hole. I hope it isn't the trans.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
squarehead
Nov 21, 2014 08:02 PM
