Do I need 4.10 gears?
Old 09-30-2004, 02:33 AM
Kurt Crosbie's Avatar
I've got a 355ci pushing out 400rwhp.
My question....
What size gear would be most beneficial for my application? 3.42, 3.73, 4.10, 4.56?
Kurt Crosbie is offline
Old 09-30-2004, 02:42 AM
cmking26's Avatar
Re: Do I need 4.10 gears?
Wow 400 rwhp thats awesome. As far as gears that depends on how you drive it. If you like to cruise I would go with 3.73 if not then go with 4.10 or higher. Im not sure about 4.56 I dont know anyone with them. If you search theres formulas out there to estimate rpm at a given speed in a given gear.
cmking26 is offline
Old 09-30-2004, 03:12 AM
1racerdude's Avatar
4.10's
1racerdude is offline
Old 09-30-2004, 10:39 AM
TransAmGT94's Avatar
4.10 is also my answer
TransAmGT94 is offline
Old 09-30-2004, 10:41 AM
Im also in the process of building a 355 would you mind sending me a list of the parts you used and a guess on how much $$$ it cost so i know how much more ive got to spend
Old 09-30-2004, 01:28 PM
You know I can't let out that kind of info...
Old 10-06-2004, 03:34 PM
mebanditws6's Avatar
Good luck making 400rwhp with the CC305 cam unless you get some aftermarket heads like AFR's that flow around 300 on the intake side. Why not get a GM 847 with that forged rotating assembly? Seems like a waste to me.
Jason
mebanditws6 is offline
Old 10-06-2004, 03:51 PM
GreenDemon's Avatar
Jason
People always want to go overboard on their cams so they can push out that last bit of power on top, but in reality, for a daily driver/Sunday cruiser it would be nicer to have a strong overall powerband. I wouldn't mind a cc305 w/ some nice aftermarket heads.
GreenDemon is offline
Old 10-06-2004, 03:57 PM
I have stock heads. They're just ported. And as for the cam...
My engine builder said the purpose of using the cc305 was to make the engine "streetable".
Old 10-06-2004, 04:00 PM
383Z4ME's Avatar
There are calculators to figure this stuff.
https://www.camaroz28.com/calcs/index.shtml
has lots of useful calcs.
I figured 4.10 was a little tall and would force me to a 28" tire.
383Z4ME is offline
Old 10-06-2004, 09:23 PM
kostya_f's Avatar
Depends on what you are looking for. On 275 street tires 4.10 will be too much. On et streets they will be ok.
kostya_f is offline
Old 10-10-2004, 10:23 PM
Capn Pete's Avatar
It depends on where your engine's red-line is going to be. For a relatively stock car (~6000 rpm red-line) running 26" tires, 4.10's are the perfect ratio IMO.....you end up crossing the line between 5500 - 6000 rpm (running over 100 mph, but not much more than ~110 - 112 mph).
If you're making ~400 rwhp, then you'll be doing more than ~110 mph, but chances are your engine's red-line would be higher (probably ~6500 rpm at least? ) which allows more speed in top gear (upwards of ~120 mph). Any faster, and yeah, you'd need 28" tires, or a higher gear ratio.
Try out this calculator.
Capn Pete is offline
Drtryder
04-22-2015 04:17 PM
camy 1993
02-01-2015 07:16 PM
Noer
Parts Wanted
01-19-2015 10:19 AM
GRN96WS6
09-08-2002 10:45 PM
funina91ss
08-06-2002 11:20 PM
Quick Reply: Do I need 4.10 gears?
