DIY stall converter install
Old Apr 29, 2008 | 04:37 PM
C5042081's Avatar
Debating if i want to tackle the converter install myself, I have access to a trans jack and have all the supporting tools needed.
How hard is this to do? is a lift necessary?
BTW this is for a 95 lt1 4l60e
Old Apr 29, 2008 | 05:26 PM
caldercay's Avatar
Originally Posted by C5042081
[snipped] How hard is this to do? is a lift necessary? BTW this is for a 95 lt1 4l60e
The most "difficult" part is unbolting everything to get to the TC. A lift is not
necessary. How many miles are on the car?
Old Apr 29, 2008 | 06:05 PM
LSWHO's Avatar
I did my first and second one myself.
First one I either botched or the tranny was already on it's way out or the converter took a major crap on it.
Second one so far went without a hitch.
Old Apr 29, 2008 | 07:01 PM
MTBeni's Avatar
I used a lift both times (on base). I don't know how you guys do without it. Getting those top tranny bolts has to be a pain. The 2 things I remember about the installs are to fill the converter before installing and to make sure its seated on the tranny all the way.
Old Apr 29, 2008 | 07:23 PM
C5042081's Avatar
80k on the car, trans rebuilt 20k ago.
I have headers/y pipe off also
Old Apr 29, 2008 | 07:49 PM
northdakota93z28's Avatar
i did it on jack stand and if you are only doing a converter you dont have to take the tranny all the way out just drop it, put the stall in and lift it right back up. with a tranny jack it is easy.
Old Apr 29, 2008 | 08:10 PM
caldercay's Avatar
I put my car on wooden "wheel stands" that I made, which gets the car
up about 18" at the belly pan. At that height, I can *very* comfortably
do anything under the car (and very safely, I might add) - dropped the
stock tranny out with no problems (no clearance issues/etc), installed
headers, installed a new FLT tranny with Yank TC.
Getting to the upper tranny bolts was a breeze, actually ... remove the
crossmember and let the back of the tranny down - I was able to get
to the bolts with an 18" extension and socket (3/8" drive that is).
Old Apr 29, 2008 | 08:11 PM
caldercay's Avatar
I had a "concern" about mileage on the tranny, but it seems you're in
good shape on that end.
Old Apr 29, 2008 | 08:22 PM
romoranger's Avatar
just get it as high as you can. I have done it twice, its not too bad.
Old Apr 30, 2008 | 12:02 AM
ttop1986's Avatar
Javier has a writeup on a converter install. It also has pictures! http://zmydust.com/converter.html
Old Apr 30, 2008 | 12:36 AM
LSWHO's Avatar
I had ZERO problems getting the bellhousing bolts.
ZERO.
Get a LONG extension and one swivel connection and you call undo all 6 bolts in less than 5 minutes. Minus the second one up from the driver side. that one requires a 14 mm open end wrench and is STILL cake.
marine1bird
10
Jan 25, 2015 12:02 AM
thenewkid
Nov 27, 2014 09:41 AM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
squarehead
Nov 21, 2014 08:02 PM
mysticslp2002
Jul 29, 2002 02:03 PM
