? diffrence between 3 & 4 channel
what are the diffrences between a 3 channel rear and a four channel rear. so far what i know the abs ring on a three channel in on the carrier and a 4 channel has a ring at the end of each axle. are all asr cars 4 channel? does a 4 channel have a ring on the carrier also? will the abs work if you put a three channel rear in an car that came with a 4 channel. any you for any info.
Re: ? diffrence between 3 & 4 channel
Putting a 4 channel rear into a 3 channel car is somewhat more difficult because you will need to precisely drill the housing for the 3 channel ABS sensor and install the reluctor ring.
-brent
ASR = acceleration slip regulation, right?
Brent is exactly right about the 3 vs. 4 channel thing, and as well about the fact that it's easier to turn a non-TCS (3 channel) diff into a 4 channel than it is to go the other way around
Henson071
Sep 21, 2015 04:31 PM
