Differential question
Old Oct 16, 2003 | 09:28 PM
rs500's Avatar
I have an RS with a 2 series carrier. What are the primary differences in the 2 and 3 series carriers and will gears from a 3 series fit a 2 series? I'm looking at some used 3.42s. Thanks.
Old Oct 17, 2003 | 07:27 AM
CODY BEHNKE's Avatar
Factory gears are not interchangable between carrier series.
Old Oct 17, 2003 | 01:13 PM
Capn Pete's Avatar
Arrow
You can buy 3-series gears (3.23's and up) for 2-series carriers, but the difference is that the 2-series ring gear will be approx. 1/4" thicker than the 3-series ring gear. You CAN buy a spacer to use with the 3-series gear in your 2-series carrier, but you also need longer bolts then, and I can guarantee you that it won't be nearly as strong as just using the proper ring gear on its own, and it'll likely shear the bolts off. I know that happened to a friend of my dad's when he tried using a spacer behind the ring gear.
I'm afraid to say your best bet is either buy a new set of 2-series 3.42's for your car (new gears aren't all that expensive) or look for a complete rear end with 3.42's already in it if you want to go used.
QuickSilver02
Apr 7, 2015 11:12 AM
737drivr
Feb 20, 2015 11:54 AM
NewsBot
Jan 29, 2015 07:10 PM
guionM
9
Aug 29, 2002 01:48 PM
guionM
18
Jul 11, 2002 01:45 AM
