Diff temp.
Old Dec 12, 2007 | 05:30 PM
96supersport's Avatar
Diff temp.
what should the tempature of the diff be after normal driving, the reason i ask is because mine gets to hot to touch.
stock 10 bolt with 4:10 gears
Old Dec 12, 2007 | 06:44 PM
wrd1972's Avatar
I have never ever seen this asked or discussed. Not being a smart ***, but it does get warm.
Old Dec 13, 2007 | 12:02 AM
too hot to touch? not just warm.
Old Dec 13, 2007 | 09:38 AM
cause4panic's Avatar
If its getting HOT! there is something wrong. it should not even get that warm on a cold day.
where are u checking the temp? the cover?
try getting it hot again and check the area close to the axle tubes and the front of the pinion near the yolk. but from the way your describing it you have a problem
Old Dec 13, 2007 | 01:23 PM
its not red hot but its def over 100 degrees, it gets hot on the diff cover, and the bottom of the differential. not as hot on the axle tubes.
Old Dec 13, 2007 | 02:15 PM
RUDEDOG's Avatar
If you really think there's a problem after a long drive pull the fill plug and insert themometer in oil. If its 175 or below no worries as this is what a cool running transmission runs at.
revrider
Cars Wanted
Apr 5, 2016 10:06 AM
plattted
9
Sep 20, 2015 11:23 AM
95z_28_camaro_4_Ivan
Aug 25, 2015 03:59 PM
Girrrrl
Aug 20, 2015 09:26 AM
realistyc
Jul 28, 2015 07:32 PM
