converter tuning?
converter tuning?
I'm looking to get a SSF 3500 TC. Do I absolutely need to purchase a programmer of some sort, or can some of the transmission shops be able to program the shift points and such? If I do need such a thing, what would be the most inexpensive way to go? Thnx
Re: converter tuning?
As a general rule there is no tuning required with a TC.
Unless you are getting a TC with a high shift extension - which you wouldn't be doing unless you were running a cam and have already tuned out your shift points and were having the TC custom built to match your tuning.
Otherwise the TC has no bearing on the shift points
You do need to remove torque management from your PCM. You can do this with some of the progammers but not all of them, hypertech DOES NOT REMOVE TORQUE MANAGEMENT. You can go to places that have LS1 Edit that will perform a basic tunes for approximately $150.00
When I first got the Midwest 3000 stall converter I used to have, the Torque Management was still in my PCM. At the track it didn't seem to be a problem. But around town if you all of a sudden deside to kick it down (especially after going around a corner) the computer would change the timing sort-of like when it hits the rev Limmiter but not quite as extreme. It did annoy the heck out of me.
Once torque mangement was turned off you get the full benifits of the high stall converter.
Good Luck,
Al
Good Luck,
Al
Good Luck,
Al
Good Luck,
Al
TM acts the same wether you have a stock TC or a high stall TC ... it simply becomes more noticeable with a high stall TC.
Originally Posted by V6toZ28
You don't need to remove TM when you get a TC. All TM does is pull timing during the shift. Removing TM is the equivalent of power shifting ... except now your doing it all the time.
Originally Posted by darrens99formul
No tuning needed.
If you have a 01 or 02 LS1 then you'll want to delete TM but pre 01 models should be GTG.
Good luck with your new verter!
TM was really messing up my world on my 99. I think it should be deleted on ALL years, or at least turned down to a VERY little percentage.
I've never heard of anyone burning out their tranny because of it being gone.
Originally Posted by RS Dragster
Wrong.
Fun, fun, fun.
armedtrigger
Feb 24, 2015 08:30 PM
ChrisFrez
Feb 15, 2015 07:49 AM
